'84 Mercedes Benz 380SL
Any tips on changing the Pitman arm seal on an '84 380SL. Is there a way of removing the old seal other than turning the wheel to extreme left or right utilizing the pressure to pop the seal?
Once the arm is taken off using
a puller, the seal has nothing holding it in. The pressure will push it out when turning the wheel to the extreme right or left but it also makes a mess. I was just wondering if there was another method or tool that could be used.
Of course the engine is running and the power steering pump is the pressure that pushes the seal out.
That's the only way I have ever done it on any other car I've had the good luck of having to change the seal.
1993 600SL, 1973 450 SL,1998 SLK 230,2018 C300, 2019 Ram 1500 Laramie, 1968 Firebird,
Well that's a new one on me. I didn't think the pitman arm on my steering box was that close to the seal. I guess I'll have to check that out.
US spec MB560SL 1986, Audi A4 and A6, Ford Taunus 1964 17M and 2.0 1975
Picture...the seal is behind C- clip, you have to remove it too.
It will be interesting to hear if it pops out. I am supriced if there is that high pressure behind this rubber lip seal.
There is no high pressure behind the seal. You can take the 4 bolts out and remove the whole seal housing and just pry it out if you cant get it out on the car.
