1996 S500 coupe
package arrived at 5:00PM yesterday, and by 5:55 it was all installed, ready to go.
Looks beautiful... put a pair of sylvania silverstars in there and lighting has improved a lot
looks decent too.
before:
1987 Mercedes 300e
whats the difference? other than there being no wipers... i dont' really see it. just reflects better? how much is the kit?
1996 S500 coupe
physical difference is that its all flush, not recessed (looks nicer)
it uses H4 bulbs
reflective housing is better, lens is new, car looks newer by a few years
lighting makes a big difference @ night
kit was $215 usd, incl. the clear corners & headlights, got lucky, normally they are anywhere from $250-$280 on ebay
1987 260E Mercedes
Typically, HID's are low beam only. There are some kits out there that will move the bulbs, but I would recomend that you avoid those kits.
You can use the fogs as your high beams. They are bright enough, and you can even retro those for HID use.
Regarding your car...
Are these DEPO or TYC brand? You upgrade your grill also?
