Sorry to hear (and see) that, I hope you're OK though. Maybe others could pitch in their grocery list.
I might also need a few little tidbits:
If 1985_300CD is only getting the taillight lens, I will get two bulb holders for the brake/stop lamps/bulbs, plus enough wire to connect the two brake lamps together, both sides. But if he's getting the entire assembly I'll pass on this.
Do you also happen to have the drain spout that is visible under the body, near the doors, and has a J shape? (orifice diameter is around 1 to 1.5cm, pointing backwards and slightly outwards). Near that spout are two other openings, no rubber spouts. Mine is missing one of those spouts. Also, I think you have the piece of wood for the ACC right? If you still have it I'll take it if it's not warped and is in good condition.
I do not have Paypal so I'll drop you a money order. Thanks
