Photo DIY- Rear Differential Oil Change
13853 Views 2 Replies 3 Participants Last post by  Kajtek1
9
Why in the Heck M-B does NOT specify an Interval for this Oil Change?? I'll never Know!
On the G-Klasse, it is on a 50,000 Interval, so I use that same Mileage on ALL of my Axles.
This procedure is the "Updated" M-B version, Using the Sealant, and the New Up-Dated Plug Prep.
Reactions: 5
Thanks for this. The 2014 Maintenance booklet shows the rear diff fluid to be changed at 40,000 miles https://www.mercedesbenzraleigh.com/static/dealer-12744/manuals/MY14_Maintenance_Booklet.pdf page 23
Reactions: 1
page 23 says "(limited slip differential only)"
I never change differential oil on my MB, but then the only ones that run into 300,000 miles had differential serviced by PO.
