'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Well, I'm quite impressed!
I got 102,000 miles from the Original Front Brake Pads! I was also shocked to see Both the Front & Rear Rotors were still at a 'NEW' thickness of 32mm/22mm respectively, so Pad-Change-Only today!
As part of my 100K service, I noticed the front pads were thin. The rear pads were 'NEAR-NEW' in thickness, but I opted to change them anyways.
Since my Mantra is always, "THEEEEEEEEE most important system in a car is: *THE BRAKES* " I strongly encourage you have a professional do the brake-work if you are even the SLIGHTEST bit apprehensive. It is not only YOU who will be injured if a failure happens... it is ALSO those of us sharing the road along side you!!!
That being said, the W212 is a very easy brake change. Please note, there are models with FIXED, and those with 'Floating' calipers.
This DIY is for a 2011 W212.056 with Floating calipers. As always, consult your WIS for proper procedures on your particular vehicle, and EPC for correct part #'s.
