1 - 10 of 10 Posts
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Yes, another stupidly easy posting.
I Lube After EVERY Oil Change.
Yes, overkill perhaps. But with what I have heard for the replacement costs of these puppies..... Better Safe than Sorry!!
Be sure to THOROUGHLY clean the nipples before lubing.
TJs, FJ40s, JGCs, G500
using compressed air for lubing the slip joint is dangerous! They should never get more than 3 to 4 (hand) pumps - otherwise the shafts are pressing against the bearings inside the transfer case. Then you will have very expensive repairs.
Harald,
After all of these years, this is the FIRST time I have ever disagreed with you.
There is NO DIFFERENCE in the "VOLUME" of Grease dispensed, between a "Hand Pump" and a Pneumatic Gun.
3-4 Pneumatic Pumps is the exact same as 3-4 Hand pumps.... only easier for us "Flojo" Lazy types!
2007 G500
Someone asked the same question above...My shaft doesn't have grease fittings...so how do you grease it? It's a 2007 G500.
96 G300DT
Clean off the dirt and I think you will find the cone shaped fittings shown in the first picture.
Discussion Starter · #8 ·
I'm not sure what year it was... 2006??, but they switched to the "Maintenance-Free" Propshafts. *NO* Grease Fittings. Brilliant, ehhhh???
96 G300DT
Yeah. On the other hand, our E300 has 250K on a maintenance free shaft with no signs of play. Of course, we don't take it through creek crossings either.
1 - 10 of 10 Posts
