With 150,000 miles on the clock.... and since I was going to Re-Do my mother-in-laws brake system..... I went the very small extra step to do the wheel bearings while I was there.
One 150 Gram tube of Mercedes Grease, and new Inner Seals are all that is required (assuming the bearings are OK... which a vast majority of the time, they ARE!).
Be sure to give good "back and forth" Rotation of the Hub while doing the Tightening and Adjustments.... you want the bearings well seated.
Please see my "Front Brake Overhaul" Post for the Disassembly of the Calipers/Rotors, to get you to the Level of the Hub Job.
