'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Well, I'm quite impressed!
I got 102,000 miles from the Original Front Brake Pads! I was also shocked to see the Rotors were still at a 'NEW' thickness of 32mm, so Pad-Change-Only today!
As part of my 100K service, I noticed they were thin, so I'm replacing the Front & Rear pads.
Since my Mantra is always, "THEEEEEEEEE most important system in a car is: *THE BRAKES* " I strongly encourage you have a professional do the brake-work if you are even the SLIGHTEST bit apprehensive. It is not only YOU who will be injured if a failure happens... it is ALSO those of us sharing the road along side you!!!
That being said, the W212 is a very easy brake change. Please note, there are models with FIXED, and those with 'Floating' calipers.
This DIY is for a 2011 W212.056 with Floating calipers. As always, consult your WIS for proper procedures on your particular vehicle, and EPC for correct part #'s.
Discussion Starter #2
Part 2
Sorry, BW 'jumbled' my photo order.. the last pic above should be 'Step 2, Remove Wheel'
Outstanding Contributor W221 Moderator
2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
You must have STP or PMS or whatever that clarivoyant thing is! Just picked up the pads/rotors for my wife's E350 on Friday!! 100k on the originals though? That's amazing!
Thanks G for being the G!
