1 - 20 of 30 Posts
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Greets.
I know this is a "Basic" post for you Pro's. I am directing it to fellow "novice" wrenchers. If you done it a million time in the past, you are wasting your time reading this post.
I use a European WIS, which has different Mileage Specs on the ASSYST/Service Sheet. "Conveniently" the USA Sheet makes the intervals to lie JUST outside the "Included Maintenance" period of 4 yrs/50,000 miles.
One such service is the Differential Oil Change. Euro WIS- 80,000km (~48,000 Miles), USA- 60,000 Miles. I opted for the more conservative interval, and am doing the work at 50,000.
Although the Redline oil is NOT included on Sheet 235.7, I have used it on other vehicles for several years, and there is a VERY positive "thumbs-up" from other forum members. I am NOT promoting it's use. Included is the Spec Sheet 235.7:
It is suggested to do the change with the Oil "warm". Use caution with hot oil!!!
Hi there, thanks very much for the DIY guides. They are certainly very helpful. I just have a quick question regarding the 463 (2002 G500). The owner's manual shows the various oil types for the Transfer Case, Front Diff., and Rear Diff, which you have covered on the couple of threads here. However the manual also indicated an oil type (DOT 3+4) for the "differential lock mechanism." Can you advise whether this is the separate system that needs to be serviced and how?
Thanks a lot!
Thanks a lot!
Mr. Bean, I think you are talking about the Hydraulic Fluid (ie. Brake Fluid), used in the Differential Actuation System. And YES it needs to be changed regularly. Personally, I do it ONCE A YEAR.
Yes, the Service Sheet for USA says change brake fluid each TWO years, but if you look at the European WIS Sheet, it is EVERY YEAR.
Since I live in a very hot/humid environment, I do it once a year. Since the differential system is right next to the brake reservoir, I do the flush at the same time.
I am due for the flush service, so I will post, if that will help you!
Cheers
2002 G-Wagen
many thanks
Just want to thank you for all the great tips! You've been very helpful.
Discussion Starter · #10 ·
Best grease is Shell Retinax HDX2.
But I don't know... Maybe in US it has other name.
Best oil for axles is SAE75W140 GL5.
It is G55 factory filling, and not the 75W90 GL5.
Rodnex,
I hope I'm not sounding like I am questioning you, but where do you get the info about the 75W140???
Here are the Spec Sheets for the G-Wagen, and there is nothing there about 140, only 85W90, or 90 wieght.
this is what i run in mine!!!!!!!!!
About Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140)
Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140) is a fully synthetic SAE 75W-140 hypoid gear oil formulated for use in both conventional and limited slip differentials.
Whilst being suitable for all applications where a lubricant of this quality is specified it is specially formulated for use in limited slip differentials fitted to Japanese vehicles requiring an SAE 75W-140 Extreme Pressure Gear Oil. Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140) has additionally demonstrated outstanding performance in competition vehicles employing limited slip differentials.
Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140) is also specifically designed for BMW differentials including the Z3 limited slip differential.
just easyer for my 2 use as this as deaLer I WORK AT has bmw and benz so i easyer 2 just grap the pump for this :) been working in my front and rear for 5 years now no problems
Discussion Starter · #13 ·
It is my understanding that the 75W 140 is for the Higher Horsepower AMG Models Only.
2007 G500
Cheers
G-AMG, This thread has some age to it, but I was wondering if you ever got around to making a DIY guide of the flush service on your diff actuation mechanism? I am planning to do this soon on my '07 G500.
Thanks a lot!
2000 G500 NMLE
Thanks a lot!
I'm not G-AMG, but here is the official WIS instruction.
Reactions: pitpro
2007 G500
Thanks Dutch!
You have a similar instruction for the automatic trans [edit] clutch mechanism fluid replace?
Thanks.
Discussion Starter · #17 ·
Thanks a lot!
Here is the Hydraulic Service DIY, which Includes the Differential Slave Cylinders:
http://www.benzworld.org/forums/g-class/1707108-photo-diy-w463-hydraulic-service.html
For the Transmission Service? It Depends what transmission type you have on your '07, 722.6? or 722.9?
722.6 service WITHOUT Torque Converter Plug:
http://www.benzworld.org/forums/g-class/1334818-photo-diy-722-6x-transmission-fluid.html
722.905 NAG2+ :
http://www.benzworld.org/forums/g-class/1721571-photo-diy-722-905-7g-tronic.html
2007 G500
Thanks G-AMG.
I used your excellent transmission fluid replacement guide on my '07 G500 in '14 (have the 722.9 WITHOUT TC plug). 10k mi and still shifting smooth.
Thanks for the help dear Sirs.
W201 190D 2.5 1991
Hi,
ive got G55 AMG 2002 from Japan and I cannot find proper diff and TC fluids for that car, found different types of fluids.
anyone can help?
Thanks!
1 - 20 of 30 Posts
