1 - 15 of 15 Posts
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Greets.
As a Preface- I am NOT Advocating this procedure since it is basically contradicting M-B's Manual "Fuel Additives are Neither NEEDED nor Recommended"
The reason "I" am doing this is because TWO of my Trusted MB Lead-Tech's/Master Mechanics (one of which is also on the regional Racing circuit) SWEAR that this is NOT a "Voodoo Chicken"... and one of the Techs states "Their Dealership ROUTINELY does this procedure on ALL Major Services".
Since I was working-up a "rough idle" problem on the W140, I was at the "Clean Throttle Body" part of the Mental Diagnostic Flow-Chart. "I might as well service all my cars while I'm at it.." Because I have read a bunch of times the suggestion to "Clean the Throttle Body"... I have YET to run across any PHOTOS of "How To", so I opted to take some pics.
I also know several folks recommend MAS cleanings periodically, as well, so I cleaned those while I had them out.
The Throttle Body "Flap" is not very accessible to "Open and Close" during the Throttle Body Cleaning Procedure , so I ended up just with the "Standard" Atomized Cleaning, Misting the material into the body neck.
Since it is recommended to do the cleaning with the engine WARM, what I did was disassemble as much as possible with the engine COOL, just to make life easier.
This Procedure will take care of MAS, FUEL INJECTORS, THROTTLE BODY, and FUEL TANK/LINES
nothing broken. finally!
Good stuff as always
TB looks pretty normal and clean.
Another vehicle i had i had to clean it every few days due to what i can only imagine was an egr issue. It would cake up with grime fast and idle would just fail. After a few months of this I sold it but 2 things i've never done that always freaked me out and have seen cause faults:
1. clean the maf, touchless or not
2. spray the cleaner into the intake esp with engine on.
Now i feel the urge to go dig in my engine and clean my tb but i'll resist that urge.
for reference, here is what a dirty TB looks like.
Gyrate,
Thanks for the pic... at least my curiosity is "itched"...
Since this was the first time digging around the throttle body, I wasn't sure if the "slight crust" around the edges of the flap was a "Dirty" Throttle Body.... but NOW I know what dirty is, Ha Ha!
93 500 sel - 95 s500
Another great post! How did this help with your idle issue?
Kevin
Kevin
Unfortunately, NO.
BUT!! Today I just finished replacing out ALL the Vacuum lines.
Although I had previously Checked all the lines, and they DID hold a 25 inch vacuum without Leak... for whatever reason, after replacing the lines... PROBLEM SOLVED!
This whole thing has been a real hemorrhoid! WEEKS of Fuel System testing, Replacing Spark Plugs, Rotating a New Coil Pack across 8 cylinders, systematically shutting off the Fuel Injectors one at a time, STAR testing after STAR testing with NO faults, even on HHT "Rough Engine Detection" sub-section....
Thank goodness I'm done...
G
98' CL500, 96' S600 coupe & the newly acquired 95' SL600
The knowledge on this board is freaking ridiculous. I could only hope to have 10% of what these guys know and can do.
Outstanding. Hats off.
Does this apply for the W140 coupes aswell?!?!?? Specifically CL500 circa 98'???
Discussion Starter #11
1993 300SEL (Sold) 2007 X5
I guess it was hard to tell seeing as you still had a rough idle issue after doing this - but did you notice any improvement in general engine performance, smoother power etc?
Discussion Starter #14
I never know if I should reply here or in 210, but what is your schedule for this?
I have been doing this at 20,000 Mile Intervals, ever since they only have "Ethanol" Gas here. Previously, 30,000 Miles.
I honestly think that Ethanol garbage is mucking up my injectors.
1991 R129 500SL
Hello G-AMG,
Would you have the procedure for the K-Jetronic fitted M119.960?
Thank you in advance :)
1 - 15 of 15 Posts
