1 - 16 of 16 Posts
'04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Yes, another overly pragmatic post on a bread & butter subject... but a item we can often "overlook".
Since batteries are such a Mission Critical Item, I like to keep mine in tip-top shape, so I am not left stranded somewhere unpleasant.
A good preventative program (ie. at each B-Service) should detect a bad cell prior to battery failure, and one of the ways to protect from a failure is keeping the fluid levels/acid balance in the normal range.
Just a few notes,
1- You are working around ACID (Corrosive), and Hydrogen Gas (explosive) so use appropriate protection.
2- When performing a conductance test, it is important to do the test with the battery in a "relaxed" state. This means several hours after driving, OR if you have driven the car, you must turn on the Headlights for 30 seconds, turn them off, then wait a few minutes for the battery to "normalize".
G
W140 Mercedes 500 SE, 1992, European, 410.000 km
Hi,
nice post as usual. But I am surprised that batteries which can be maintained still exist. Mine is maintenance-free but it was not bought at the dealer's.
nothing broken. finally!
Hi,
"maintenance free" is just a term, like "sealed for life transmissions" cough mb cough!
the only true such batteries are sealed deep cycle solid cells like optimas, but they make terrible cranking batteries. if its a primary battery, it will be of the good old 80 year design, with acid in it. and water. whether some moron company decided to seal the top and sell it as maint free is their choice.
amgs posts always make me want to buy more tools.
1998 S600 LWB 2011 GLK 350 4matic 2013 Sprinter 2500
Kinda like permanently lubed bearings.
I want amgs 16' ceiling.
1997 S500V, 1999 S500 grand edition, 2006 s65 amg
this helped me alot on my mazda fluid was low and it wasn't functioning right until now :) once i get a new battery for my w140 i will maintain it(i have aftermarket on it now i want to get the original) :)
thanks again great post :)
Great writeup!:thumbsup:
Wheres the submariner? Hehe:D
I ALWAYS take it off now,,,,,,
So I don't have to hear the Smart-Alick-Y comments....
the last time i saw a battery like the one in AMG's pictures was about 30 years ago. But i live in different part of a world so it seems there is different standard in europe and USA. Of course my last battery in my W140 was maintenance-free and it lasted 9 years. usually these batteries last much more than 4 years, I would say the average lifetime is more than 6 years if they are made by good companies. the price for my new one (i replaced it 2 years ago) was 150 EUR and it is made by Bosch (moron company?).
30 years ago? seriously? No you didnt. :rolleyes:
like i said, it is the e.x.a.c.t. same battery just sealed on top. id rather have the real thing with the acid access holes. it's just marketing
I am serious. I even do not know if it is possible to buy here a battery like the one on the picture. most probably there are some regulations in europe which are not in force in USA. I am really not sure ... do not know much about this. I do not know what is the main difference between the batteries, i would not say that maintenance free one is just sealed ... the vapours should excape then outside somehow? If not, the battery can explode. If yes, then the level of liquid would decrease over time but it does not happen.
What did Galileo Galilei say? If think something like: "... but it still turns ..."
98' CL500, 96' S600 coupe & the newly acquired 95' SL600
Considering my battery died yesterday in my S600, this would come in handy... NOT. I'm replacing the whole freaking battery. I'm glad I got my trunk open before the battery completely died.
Black on Black 1997 E420
Battery voltage
G-AMG,
My battery is 3yrs old and I added distilled water according to your instructions. Though I do not own the fancy device in your write-up, I tested the voltage afterwards and the readout is 12.24 volts(with the ignition on position 2). Is this reading within an acceptable range? It drops to 11.90 with a running engine.
1997 S600 (sold)
G-AMG,
If that is true, you've got a problem. With the engine running and the alternator functioning properly, you should have around 13.5 V at the battery terminals. Your charging system has a problem.
Brett
1 - 16 of 16 Posts
