1 - 16 of 16 Posts
1999 SL500 Sport
Has anyone else experienced this?
My roll bar keeps moving up a bit for no apparent reason. I have tried watching in the rearview after a bump or a turn, but that doesn't seem to be when it's happening.
I can be parked (car off), or driving, and an hour later, I notice it will be maybe a third of the way up. I keep it down when I'm driving, so when it appears in the bottem of my rear view mirror, I know that it has started on it's way up.
It never POPS up the way I imagine it would deploy in an impending rollover.
Just creepy, annoying 1" increments it seems.
Any ideas on what to do?
:confused:
That is not normal as the system should not even be pressurized.
2015 Jaguar XF R Sport Twin Turbo, 1992 500sl Pano, 1999 CBR 1100XX, Super BlackBird, Jaguar X Type
Whoooooooooooo! maybe it's a German relative of Christine :eek:
It may try to creep over your head and snap you back into the trunk. Stranger things have happened.
Try to avoid spending too much time looking in the rearview you may crash.
Sorry! I can't help.
1996 SL320 White/Gray
Something vague in my memory says I did have this problem which was caused by something not allowing it to go fully down. Check to make sure there is nothing in the way of it's final travel. Take a hard look at the rear screen installation.
1999 SL500 Sport
No, this happens whether the windscreen is on or off.
It lowers all the way down with the button, but 5 minutes later it's on the rise again.
2009 SL550 Silver Arrow Launch Edition, 2013 Mercedes Benz C300 4Matic
It is haunted if nothing is in the way of it resolving the reverse rest process.
If you really want to find out what happened, remove the panels and take a look what is pushing it up. As I said before, the system is not pressurized unless the pump is running, so it shouldn't be a hydraulic problem.
1999 SL500 Sport
Gotta love the dealer
So I stopped at the dealer today to order a valet key. I asked the service advisor there if he had ever seen or heard of this rollbar issue. His answer... "Well, what happened is, something in the mechanism probably broke" Wow! Sounded way too technical for me. I got the impression that for $120 or so an hour, his guys would be glad to get right in there and scratch their heads about it. Too funny.
1999 SL500 Sport
The mystery continues...
Strange. I removed the entire bose factory stereo system from my car, and the roll bar movement has stopped. New sound system not in yet, no wires cut, just unplugged everything. Why would THAT fix it?
1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
I've got a 93 with no Bose. How about making a brother a deal ? :D
You need something to get it up ? (I mean the rollbar)
1999 SL500 Sport
Discussion Starter #13
Open to offers
tdoriat,
I have the whole system on ebay for $250 or better.
Always open to trades though. I am most in need of a tan overhead dome light assembly, fuse box cover, and the trim pieces around the visor attachments.
Shoot me a link for the Fleabay listing. Thanks !
1993 Mercedes Benz 500SL
Well mine does the same thing. It can be sitting parked and I will come out and it has raised a bit. I guess there are two that are haunted by the same ghost.
R129 sl320 '99 / W201 190E '90
hi,
I had strange roll bar popping up when I flashed the headlights behaviour with the key turned but engine off. Unusual behaviour. A bad battery was the problem. I am not claiming to know anything but just in case.
Good luck, Darragh
1 - 16 of 16 Posts
