When the engine start cold it does everything it supposed to do by revving higher and then drops to the desired RPM of about ~650 and ~500 if set to D.
All that without a single sputter, smooth engine.
But, as the engine temperature reaches the 80 degree mark, while the idle seem to be continuing to be good, if one revs or try driving (under load), a distinctive sputter occurs until about 3000RPM or so.
This problem started gradually about a month ago and getting worst.
So my question is:
If the distributor caps were bad, it would be sputtering cold and at rest when hot as well, not sputtering just when accelerating up to 300RPM. Right?
What you people think I should check next or change? The ignition coil? Or bad distributors can create these problems as well?
- Spark plugs changed (proper F8DC4)
- Fuel injector all good because I removed them and made it test by a specialist with proper equipment plus a clean with ultra-sonic.
- All vacuum lines and air tubes sealed and I know it worked because the RPM crept to 900RPM and now never does. Thus, air leak solved.
So my question is:
