380 se 1983....280ce 1981
My CD for the 380/500 m116_38 motor is unable to open the following file...07.3-230. It is concerning removal of the throttle valve and replacement of same.
Specificly I need to know if the throttle valve assembly is able to be unbolted and removed vertically through the opening in the inlet manifold (after the fuel distributor and air delivery pipe is removed) or does the inlet manifold need to be removed first....In other words does the "butterfly valve" and its flange fit through the opening where the air delivery pipe normally sits?
I await your collective knowedge
