2008 C300
I got this PCMCIA to SD card adapter few days ago. When I insert it with a 4GB SDHC card to the PCMCIA slot on the front panel and select the memory card for audio input. It says no playable files. I format the SDHC card using windows and tried several different audio files and none of them worked.
Does anyone have this problem before?
2011 C300 Sport, P1, MM, Wood, HFS, Palladium Silver
Could it be certain audio formats that MB does not play?
I know it plays .mp3 format.. but definitely not .flac format. I haven't tested any other formats besides the two.
EDIT: Also, in response to the 2GB limitation, I found this on SanDisk website.
Problem: Device fails to read CompactFlash cards over 2GB
Question: Why can't my device read the CompactFlash card I inserted?
Answer: Certain devices may have trouble reading cards over 2GB due to FAT16 limitation. These devices can NOT read a FAT32 file system. If there is a firmware update available for such device, it may resolve the issue. If no such update is available, the device is limited to 2GB capacity.
