Hello everyone,
I will try to be as clear as i can: Well, Can't get the passenger window up or down via the any switch. I took the door panel off, follow the wriring all the way to the driver door, nothing is broken. There is no power going to the window at all.
I managed to get some a + tive connect from the driver wirring & a ground , when negative connect to a black/blue wire the window goes up, then same negative connected to a blue wire, window shut, but i can't have both wires with ground at same time otherwise central locking fuse blow, wich is the same as the windows for some reason.
Look like that the central locking is a aftermarket. But can't find anything loose.
Thanks for your help
