2005 CLK 500 Coupe
Good afternoon all, I have a '05 CLK 500 Coupe and the problem I am having is when someone sits in the passenger seat the automatic seat belt doesn't work all the time. I also am getting an SRS code for the seat belt buckle. Anyone have any thoughts on this issue or maybe have a similar problem. I just went out of extended warranty....any help would be greatly appreciated. Thanks
Do you mean that the seat belt presenter is not extending? That could be a problem with the door sensor - it's a small plunger switch on the "B" pillar below the latch. It may not be registering that the door has opened and closed. What is the SRS error code you are getting?
mercedes clk 350 sport convertible.W209.
i had a problem with the seat belt on the passenger side, and the problem was the plunger on the b pillar just wot rudeney said.
