'00 w163 55 amg (sold) '02 w208 55 amg '03 w163 350 inspiration
:confused: a bit curious. I realize there a LOT of other little buggy things out there that can rattle the nerves of even the most obscure MB owner, so this is my own:)
I've searched for this but havent' found exactly what you call it or the part #, assuming it is or has it's own part#. the plastic clip on the pass side footwell that holds up the panel, yeah that thing. Trying to check my cabin filter & the peculiar piece of 'stuff' will not 'plug' back in to place. want to fix so my footwell panel doesn't just sag in pass area. no 1 has noticed but me but I'm slightly anal about this 'thing' I call a 55. should I just brouse my local salvage yard for this?
'07 C280 4matic, '06 530i, '98 ML320
oreif,
Look at that clip carefully, both sides of that clip must've been pressed in; leading to clip not holding tight. Take a small screw driver or a small plier and 'expand' both sides of that clip, it should be good to go. It's hard to explain; but, when you look at the clip, you will see what I am talking about.
