1 - 10 of 10 Posts
· Super Moderator
02 ML500, 00 ML320, 05 E500 4M Wagon, 99 ML430
I have been having good luck with huskerparts.com.
There is mbpartsworld and also parts.com. They are all very close on price.
The parktronic control (0009003706) that lists at $137 is $96 at Huskerparts.
I am assuming you want new parts. If not I am sure some of these items are on eBay in working shape for a lot less money.
2005 E320
Thanks! What about things like the sensors that aren't so easy to find? I tried searching a few of the numbers and Google does not even have results. Am I stuck with buying through a dealer?
2005 E320
Do you know if there is any easy way in EPC net to find all the parts you would need to retrofit a system? For example to retrofit the sensors I could search something to see all the parts for that without having to manually go into every menu? For some of these items like the surround cameras it just says "IMPORTANT INFORMATION" and a list of codes but no part numbers, like this:
Hi where it says "see 72/331" that means group 72 which is doors then subgroup 331 which I think is mirrors. Just a little bit of inso. Also try group 99 which is accessories might list numbers there. Remove filters to use group 99
2005 E320
Discussion Starter · #7 ·
Thanks. Also, what happened to WIS? When I logged into EPC to launch EPC as of a few months ago it used to also give me an option to launch WIS? Not anymore? Is there a way within EPC to get the service documents like WIS?
I'm a huge rookie. Sorry.
· Super Moderator
I am not sure how you were getting WIS for free. EPC is free.
If you go to Startekinfo.com you can pay for one day and download the dozens of service documents you will need to complete these retrofits.
2005 E320
Discussion Starter · #9 ·
I don't remember either. It was about a year ago and I remember seeing a button for WIS and a button for EPC and I remember searching documents.
1 - 10 of 10 Posts
