1 - 8 of 8 Posts
I am having trouble finding the part number for the seal that fits around the sunroof opening between roof and glass.
I have epc, but not sure if part 11 in diagram, A2107800098 is the correct number.
1998 E320 sedan
Yes the manual I have for M-Benz E-Class 1996-99 has that same part number. The cost from the dealer would have been $71.00 and a half hour to install.
Banned
1999 E300 TD
I believe the part number is 210 780 00 98.
I would call Stateline Auto--800 849 2765---they are very competitive and over fifty bucks ships free.
Have a good holiday.
Thanks for the confirmation guys. Hope you are enjoying your holiday.
Unfortunately, being in Canada, the price will probably be a LOT higher. The sunroof cables were $80.xx vs about $44 or less in USA and $28.xx and one place. But as usual, I need the seal yesterday :(
Car is going in next week for some rust spots around sunroof and we have to remove the old seal first. May be able to re-use it though.
1998 E320 sedan
Hopefully the old one will still work. Not sure where else other than the dealer you can find that. I tried autohausaz and ebay and none for the W210. Rust on the roof mmm, I have rust everywhere but on the roof lol.
92 500SEL to 01 E320T current 2014 lexus LS460
There is a up side and rear side, check the position before installing. I had some rust spots refinished and had them install a new seal, and they screwed it up. Install the corners first and then the rest. The idiots worked it around and then cut it because of the excess, I made then buy me a new one and installed it myself. NO CUTS
Thanks for the tip! I will probably have them put the old one back, and then if it doesn't look right, get a new one and install it myself. It's an expensive piece of rubber to screw up!
BTW, several of the on-line MB parts suppliers don't list this part.
1999 E320 w/118K
Does the seal simply press into place?
Another post mentioned having to remove the sunroof and the headliner to replace the seal.
1 - 8 of 8 Posts
