CLK320
So silly me, when I had the whole back portion of my car apart over the weekend I forgot to write this down before I put everything back together. I thought it would be as simple as giving the dealer my VIN and described what I was looking for, apparently, it's not that simple. Does anyone know what that part number is or where I can find it? I would hate to have to pull everything out again just for that part number.
Thanks in advance.
I happen to have mine out at the time so it is either
49104 20149/06
Or
210 820 11 02
The two sequence of numbers are separated by a Benz symbol. You do know you can also see it if you just slid into the trunk and look up.
CLK320
Sweet!!! Thanks RJBENZ. Now let's see if I can track down a couple extra ones.
E320 1996/300E 1992/E320 1995
The housing and speaker are sold as one unit and cannot be bought from MB separately. The part number mentioned 210 820 11 02 is for the complete unit. You can separate the speaker from the housing but just do it gently so as not to break anything.If you need just the housing you can get them on the net from a source in the UK. Search under Mercedes Speakers and you should find it. You could also look for used housings.
