1 - 9 of 9 Posts
2000 E320
Anyone know where I can get this part? Dealer is charging $175 (special order) and all I seem to find online are used parts on Ebay. Please help.
2000 E320
If you haven't done a ECU/tranny reset yet - I would recommend doing that there is a slight chance something might change after the reset.
Sometimes it also can be a dirty throttle body.
The OEM sensor is Hella, and actually you can get the behind-the-pedal assembly used if you make like a $60 offer on eBay, the dealer part is Hella sensor only at $175 the OE Hella part is like $120 in internet aftermarket like partsgeek.com.
If you replace with a new sensor do a calibration procedure:
quick question about tps (throttle position sensor) - MBWorld.org Forums
Also a failing fuel pump can also set off the throttle sensor circuit.
It can be a little pesky, if it was me I would try the reset, buy a used assembly, and do the calibration
92 500SEL to 01 E320T current 2014 lexus LS460
If it goes into the limp home mode when accelerating hard it is bad. As with anything on E-Bay be aware, get from a reputable source.
The most common name is Pedal Position Sensor.
You are getting it cheap bro. When I had one failing on my car 3 years ago, the retail was $450 and I was happy to find it for around $300 at Duval
Darn expensive potentiometer.
2000 ML320, 2001 E320, 2011 GLK 350, 1998 Ford Ranger, 2003 Toyota Sequoia, 2014 Nissan Leaf,
For 2001 E320:
Ordered at AutoPartsWAY.com
Part Number: HEL1786802
Part Name: Throttle Position Sensor
QTY Ordered: 1
Item Price: $122.87
SHIPPING: FREE
ORDER TOTAL: $122.87
1 - 9 of 9 Posts
