1 - 11 of 11 Posts
· Outstanding Contributor, Vintage Moderator
450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro 300sel5spd R+C107galore
Plugs into the headlight.
Vacuum euro headlights have no place for this connection.
I think the early non-vac euro headlights do have the plug.
US headlights definitely have the plug.
.89 560sl..07
Discussion Starter · #5 ·
Interesting day today. I bought a set of banana turn signals and grills from dan the man dgosh. But what i found is that if you have the vacuum front headlight wipers, you cannot mount the banana turn signals lights. This sat i have help coming over to remove my front euro bumper and see if i can disconnect the headlight wiper gizmos and then mount the banana lights. Ill never use tbe headlight wipers but ill keep everything for the next guy. I have to remove the front bumper to get those two amber boxes i
Off for you cant get a phillips screwdriver in to remove the wiper box either. Friday im having to pinstripes put on front fender to rear tail light right along the ridge . Im thinking 2 small stripes, maybe tan to match the top and interior.
· R/C107 Moderator
1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s ALL SOLD
Neither of the front turn/park lights is plug and play on any of the "Euro" headlights. On the early style there is a plug receptacle but it is not wired for the front turn park lights. I tapped into city the light wire, side turn signal wire and ground wire. I used some round female plugs from a parts car to wire the plug receptacle. On the vacuum adjust lights you have to cut the plug off and splice into the proper wires. That is what was done on my '84 500SL.
.89 560sl..07
Discussion Starter · #7 ·
I dont understand what "into city the light wire" means.
Im sure its a typo i just deciper the code
From Rowdie:
I don't think it was a typo. The "city light" is the small clear bulb under the main h4 bulb. It turns on when you turn on the parking lights. It is intended to be a light used for parking providing a low draw on the battery.
The amber "parking lights" or "side markers" in the US operate in the same way as the city light. So by taking electricity from that to provide light to am amber bulb would provide the desired US functionality.
The blinker bulbs in the amber section provide your blinker light (electricity). All you need to do (if desired) to create side marker lights is to in some way add a "bulb" to the amber section for a side marker, as the euro amber section can be seen from both front and sides.
How do you get a second "bulb" I. The amber section for your side marker? You don't, you swap the turn signal bulb for a dual filament bulb?
But wait, the socket for the turn signal is a single filament? Yes. You have to go down to autozone and buy a socket (or pull the one out if your hideous electrical boxes) and somehow secure that dual-filament socket into the place of the normal blinker socket.
Ok. So then you've got two wires in this new dual filament socket. Where do you connect them? One goes to the wire that ran to the original blinker. The other goes to the city light wire.
Make sense?
I will see if I can find the threads I used when I did this.
.89 560sl..07
Discussion Starter · #10 ·
Thanks for this educational writeup. Its more than I thought. But im beginning to understand.
So i dont need to put any other lights on or under the front bumper to obtain turn signals
On the front of the car. I just modify the light socket in the side light markers and install a dual filament bulb
and then wire it accordingly.
I ll wait now to see if fonzi can find that thread
Here's some stuff I found that I documented in my 1973 rolling restore thread.
Edit: it looks like none if that has anything to do with dual filament. Maybe I did it in my SLC convertible thread.
- Installing Euro Headlights to be a reversible change. http://www.benzworld.org/forums/r-c...-euro-headlight-conversion-3.html#post4695431 .................................. WAS going for this look: http://www.benzworld.org/forums/att...73-1973-450sl-after-accident-what-450slsm.jpg
Turns out to be more work wiring to get sidemarker-turn signals and under bumper turn signals all to work right. How do we do it? Still trying to find out: http://www.benzworld.org/forums/r-c...9-help-w107-us-euro-headlight-conversion.html Must be easy for some people, and they don't require any wiring mods: http://www.benzworld.org/forums/r-c107-sl-slc-class/1486875-us-euro-headlight-replacement.html
1 - 11 of 11 Posts
