So I finally got to do my first real job in my new man cave with the lift, electricity and airlines all in place and set up.
I have been running around without a parking brake for the past several years because its not required for inspection in CT and I was too lazy to address it. But in NC they do have yearly inspections and the parking brake is on the list of things that need to be checked. So this weekend I changed my brake shoes.
So here is my how to do it.
1) If you go to the manual you will find two special tools are needed. The first tool is for the hold down springs. For this I used a special tool that I bought 35 years ago for working on Toyota drum break hold down springs. But a 1/4" rod this a slot cut in it with a thin grinding wheel should work fine.
2) The second tool is the return spring removal tool. For this I used a standard Snap on cotter pin removal tool.
3) With the hold down and return springs removed the shoes can be spread apart and removed from the vehicle. You could just put new shoes in adjust and be done. but I had the cables disconnected over the years and needed to fix that as well.
I also had a second problem. The spring kits I got, with I am not sure if it came with my shoe kit had different size springs than the original springs. The hold down springs were completely wrong and the return spring near the star wheel would not rub against the star wheel as the original one did and is supposed to. I decided to reuse all my old springs. See the photo comparison.
Since I had my cables disconnected just ahead of the rear drive shaft flex coupling, I was able to pull the brake shoe cams out unpin them to remove them from the cable, disassemble clean and grease. I don't believe that could be done without disconnecting the cables but it really isn't necessary.
With the cables needing to be connected the exhaust system needs to be removed to gain access to the cable adjustment.
TBC
TBC
