I just put in new brake pads and rotors, all around on my 2000 ML320. I adjusted the rear brake emergency shoes as everyone says. So that the rotor will not turn and then back off the clicker wheel 4 clicks. The problem is that I have to press the emergency brake pedal almost to the floor. Even then, it does not hold the vehicle when in drive with a bit of gas. I read about that adjuster under the car beneather the front seat area. I can see the allen head bolt thingy in the adjuster. If I'm under the car looking up, which way do I turn to take up some slack, if that is what I need to do.
Any help is appreciated.
Thanks [:I]
Thanks [:I]
