Does any one have any experiance with a product called "Ulitma Paint Guard Plus" it's supposed to be a super wipe on and walk away product, the makers caim it to be the fastest and easiest way to protect your paint and give your auto a great shine.
Just wandering if anyone knew anything anout this product?
2005 230 Kompressor
Ultima makes some very good products including their polymer sealant- Paint Guard Plus. Apply as a thin coat (if applying multiple coats wait 24 hours in between to let the polymers cross-link and bond to the paint), let dry/flash, then wipe off with a microfiber towel to remove any residue.
This is a very good product that works well on a clean/prepped surface. It can be applied over a wax or other protectants if you do not want to strip off existing protection.
Should give you between 3-6 months or more of protection. It is pricey, but a little goes a long way. Another good one is Optimum Opti-Seal, another wipe on/wipe off easy to use sealant for comparison.
Lots of threads on autopia.com on this product.
