1998 S320L W140
Hi guys,
A little advice on what to do. I scanned my 1998 s320 and these two codes popped out. P0809 and p0341.
Engine runs fine and idles great. Does not have hard start issues when engine is cold nor hot.
On rare occasion it does loose power between 3800rpm to redline. But again very rare.
Just had my cyl. Head and gasket changed.
1996 s320
This thread talks about the P0809 code:
Here's a thread talking about the P0341 code. It is a different car but same engine as yours:
Since there has been some work just done on the engine, I'd first check the wiring to the cam position sensor. The second thread talks about proper shimming of the cam sensor. That probably should be checked.
1998 S320L W140
Thank you act1292. Will double check everything and proper shimming. If no improvement i guess i have to bring it back to the garage where i had it serviced.
