I have a 2010 GL450 with this code P0715. Indy just retrain the transmission and said drive it again. Light came back on. Indy is saying you need a new transmission, The GL has 65K miles on it and transmission is smooth and drives fine. Just before I got the check engine light the gear did slip and I could not accelerate the car its as if was in neutral gear. I pulled over shut off the car and restarted everyting was normal but p0715 code was on. Any help would be great. I did change tranmission fluid few months back. Car drives fine.
