1998 SLK 230
I have a P0455 message on my 1998 SLK230 with about 70,000 miles. Besides the check engine light, occasionally the yellow low fuel light will blink even when the tank is half full. I have checked the gas cap, flipped the gasket and lubricated it and it seems to hold well. If I come back to the car after it has been off for several hours, and loosen the gas cap, I get a good blast of pressure from in the tank so i think it is holding well. I have cleared the code and it comes back. What would be the next area to check for this fuel system message.
1998 SLK230 240,xxx Miles
Just renewed the vapour lines on the carbon canister - one line was fractured but I still had pressure in the gas tank !
Don't know if it would have prompted a PO455 - remove plastic fuel filter/pump cover to check - most likely the small bendy line going to the black plastic canister
Bound to need replacing anyway if never done - ordinary fuel line (about 5/16) but use 5/16 'fuel injection' hose and new clips if you replace the 2 high pressure lines to the filter and pump (worth doing at the same time)
Oberoi
