Had a CEL come on a couple days ago but it went away by the time I made it back home. Hooked up the OBDII scanner and found the following codes:
P0300
P0700
Tried to clear the codes but they came back. I've searched the forum and saw that the P0700 code requires hooking up to SDS to clear the ETC.
Thoughts?
Purple Moderator
You are correct. Actually many pro grade shop scan tools can get to the ETC.
The Snap On Solus is one example. Call around to some shops. You will find a place
that can clear the codes from both modules.
