Hi guys,
This is my first post. I have the above notes for fault codes on my '08 CLK350. I want to emphasize that the engine number is outside of the noted dreaded balance shift issues. I pulled the codes from my iCarsoft i980. I have reset the CEL and the codes have persisted (P0016 Crankshaft Position - Camshaft Position Correslation Bank 1 Sensor A and P0017 Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B). Also noting, I have zero performance issues, maybe a slight shake at idle.
To me this indicates a problem with the sensors? But I have also read a lot about the Cam Magnets?
My wife stopped for in for 5 mins at my local independent Merc specialist, and he tells us that when plugged into the Mercedes SDS system, it is definitely a timing chain issue and that will cost $2100. I am struggling with this diagnosis as the car only has 140,000 km's.
Some help would be very much appreciated. Thanks guys
