1 - 9 of 9 Posts
2000 ML 320
Hi all,
I just replaced both of my Oxygen Sensors Pre-Cat, however my ODBii scanner still reads with a P0150 code. Got any ideas?
Thanks.
Purple Moderator
Did you try to clear them? Which specific brand and part number did you install for the sensors?
What king of ODB scanner are you using?
02 ML320 06 ML500
Agree.
1. Where did you buy them?
2. What make?
3. What part number?
4. Are there any other codes?
Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
I suggest you read this thread wherein 43sqd has given advice on a similar issue - and save him some typing.
Summary: member had P0150 codes & misfires, replaced O2 sensor pre-cat, could generate further misfires, advised to have catalytic converter tested, and (no surprises here) failed to close thread with post on outcome/solution.
2000 ML 320
FOLLOW UP
Guys,
Thanks for the input. I just read it again and so far, no codes. I will keep a closer look and see if it pops up again. I'm hoping to get it smog checked tomorrow.
Response to some of the questions. It is a Denso Part#234-4174 (both sides) purchased online from autohausaz.com
My OBDii scanner is an Actron CP9135. Its several years old, maybe its time for a firmware update or something..:)
I forgot to mention, in the process of replacing the sensors, the clip holders were brittle and it broke. I managed to zip-tie them temporarily. Do you guys happen to know the part# for those clips?
Thanks again.
02 ML320 06 ML500
Guys,
Thanks again.
The Denso part # is correct for your vehicle, but a search with Autohauz reveals that they only sell Bosch sensors.
Your Parts Search Returned 1 Part(s)
If that clip is indeed what is broken, the part # is 163 542 13 40.
2000 ML 320
1 - 9 of 9 Posts
