1995 S320 Got error code bank 1 sensor 1 no activity detected so I ordered the sensor when I went to put it in the wire was 5 inch the original had 12 inches i called them they said you need( downstream) well I got it next day. After I put it in the engine light came back on after an hour, checked the code got the same error code. took my car to the mercedes mechanic he said my car only has one sensor I should check my cercuit breakers,because they will charge $100 to diagnosed it.I need to get this car pass the emission any help will be greatly appreciated thanks.ps I reset the check engine light, don't know how long it will stay off
Hi how did you solve the problem!? Did you finally got a signal for the other bank!?
