1980 450slc, 1980 280sl, 1992 300ce
On a '92 300ce, where does the oxy sensor wire end up? It disappears into the cabin. Never seen that before. Thanks.
Duplicate post. Remove the passenger side carpeting and look for the blue wire.
Thank you, sir. When the first post didn't appear right away, I thought I'd goofed it up and lost it. I guess the carpet is amenable to be lifted without tearing it.
1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
the footwell carpet has snaps on the back corners, and its a whole assembly with molded foam on the bottom. I believe you lift it up starting from the bottom/back,with the seat moved fairly far back, then pull it out so the upper front part comes out too. there's a pile of stuff under there, the OXS connectors are under there, and behind the metal foot plate that you can remove with 1-2 screws, are a bunch of modules including the alarm system, the SRS (airbag) controller, etc.
