1 - 9 of 9 Posts
89 300E; 00 E320
Most of this info came from you guys, but I did go off-site for a couple of things. This is just to have it all in one place.
A balanced O2 Sensor will show 0.45 volts on average and keeps fuel mixture at 14.7 to 1.
G3/2 Heated O2 Sensor ----- Testing the Component
Mercedes Benz Model 124 with M103 engine
124.030; 1989 300E; 103.983; 3 Liter
G3/2 Heated O2-sensor In exhaust pipe, rear of transmission
G3/2x1 Connector, O2-sensor heater coil (2-pole) Left side of front passenger footwell
G3/2x2 Connector, O2-sensor signal (1-pole) Left side of front passenger footwell
Unsnap and remove carpet in front right footwell
With ignition off and key out.
Locate and disconnect O2 signal connector G3/ 2x2 (wide screwdriver gently turned should unclick it)
Insert one single wire strand into connector and reconnect as tight as possible.
89 300E; 00 E320
Discussion Starter #2 (Edited)
Start engine and connect multimeter for DC voltage reading range in hundredths (.00)
(red to wire strand just inserted)
and ((black to ground (may use door closing eye))
Reading for a good sensor should fluctuate from 0.2 to 0.8 with 0.1 being (lean) and 0.9 being (rich); and average 0.45 volts (balanced). My readings were 0.19 to 0.72 and started cold at 0.49.
Pull a large vacuum hose from intake and reading should go to 0.1 (lean). Mine went to 0.06.
Could not identify fuel return line (51) without removing air cleaner so I did not check to see if the sensor would register rich if the return line were to become restricted.
After testing is complete, put everything back the way it was.
Wiring Diagram: Electronic Engine Controls 118-1
W124 Moderator
Nice write up. Mod should put this in the DIY section
Jayare
MB 260E, BMW 735i, Range Rover Classic Vogue SE
nice....could you please guide me where the other end of this vacuum hose connects...thanks in advance
89 300E; 00 E320
Not sure where the other end connects, but it is heading back on top of the transmission beside the bowden cable if that helps.
Thanks got it....now i know why my upward gear shifts were rough and delayed.
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
Yep the modulator uses the vacuum to time the shifts correctly.
1 - 9 of 9 Posts
