'85 300 TurboDiesel
I acquired a 1985 300 Turbo Diesel that runs great. But, I need to know how to start it in cold weather (below 32 degrees); and, I need an owners manual or shop manual.
92 500SEL to 01 E320T current 2014 lexus LS460
No problem, turn key wait untill light goes out and start. If it really gets cold there is a engine heater installed that can be plugged in, the cord should be in the grill area. 32 should never be a problem, I used to go up to upper Wisconsin, leaving it out and never had a problem or ever plugged in.
1991 300 SE
Also, the following need to be in good condition:
Battery
Starter
Glow Plugs/Relay
Compression
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Call MBUSA, 800-FOR-MERC. They can supply all the manuals you need.
Len
'80 450SLC Afro RHD Ikonengold, '01 113 W638 'Liz Hurley'
jdc1244a - 1/30/2005 1:01 AM
Battery
Starter
Glow Plugs/Relay
Compression
I would just change the above order starting with Compression.
Had a Diesel VW Golf I with same problem but in Africa Celsius effect is seldom felt.
jdc1244a - 1/31/2005 8:24 PM
Needless to say poor compression would be worse case…
I agree, when it is a case of advice for someone technicaly educated.
Did not get the feeling of same from the poster of this topic. Just wanted to give the order of the culprits as per significance...
