1 - 8 of 8 Posts
1992 W124 300ce sportline , {1992 W201 2.6 (totalled) }
I have been having problems with warm start so as steps to fix it - i had bought and OVP relay. Well with 70 degree today I went ahead and replaced.
When I removed the battery - I found that my battery tray was rusted - so I wnet ahead and fixed it anyways...
here are some pics of what I found..
95 E320 Cabriolet, 140K
I'm surprised MB still made battery trays from metal. Over the years I've had a number of battery trays dissolve from rust. So for every metal battery tray I own, I now grit-blast the rust and paint with a rubberized paint (the dip-type advertised for tool handles) to seal out the elements. Somehow, regular paint just doesn't do it.
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
You call that rust? Ha!!! That's nothing. I only WISH that the tray out of my 88 TE looked even half as good as that. Here's what was left of the tray from my TE:
http://bos-engel.com/benz/rustytray.jpg
Now THAT is a rusty battery tray. The retaining nuts at the rear were reduced in size so severly that I had to use a Vise-Grips to remove them.
That's what happened when the wealthy previous owner did absolutely no cosmetic maintenance to the car for 15 years. And it sat outside. Under a tree. Unless the hired babysitter used it to take/pickup the kids from school. Must be nice...
'84 300D/ dakota benz trk. Sold... miss it. "88 260E '91 190E 2.6 '89 Volvo 240DL "85 300D
that OVP will most likely NOT cure your hot start problem. also, from what i have read those like you have pictured are an old style with issues. do a search on user mountainredneck. you will see a link labeled problem solved!! read it. i wish you luck, i have been there done that. it is frustrating.
1988 300TE 217K miles and counting.
Rusted tray?
Thats no longer a tray, but a pile of rust.
Discussion Starter · #6 ·
mountain...
i saw ur post on the hot start problem fix - i know i have to do it - it is just that I bought a few suspected parts along the way - this was one of them so eventaully i will do the injectors and if that fails the fuel distributor...
1 - 8 of 8 Posts
