96 C36
Hi All
Can anyone tell me where the outside temperature sensor is located...has anyone had the problem of the temperture display going haywire...eg,jumping from 13C to 55C and then fluctuating up and down the temp range.
Thanks in advance for any info you can supply me with[:)]
CLK55/G500/E55/ML55/etc.
Hi All
Your temperature sensor should be below the front bumper, near/in one of the tow hook covers. If you are getting weird readings, it is almost nearly caused by a sensor that is either missing or damaged.
-s-
96 C36
Thanks Scorch....I will check it out(when it stops raining!) I appreciate your help...Ka...
Thanks Scorch....I will check it out(when it stops raining!) I appreciate your help...Kamz
