My drivers side remote mirror doesnt work...inside switch is fine, mirror moves soemwht, but not as it should..Any ideas of how to take off plastic covers so i can get to the back of it to see whats wrong ?
Discussion Starter #2
Becky, have the glass mirror's been removed?<br> sounds like a problem I had. They need to be snapped back into place, I thought they would break if pushed on any harder, but that was my problem
98 SL500
RE: Outside Mirror fix...Bob Terry
hey guys have the same problem, but one of the clips came out. Need a fix,it will move up and down but not left and right. At this point I think the glass needs to be removed
Outstanding Contributor Always Remembered RIP
216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
With the late type round mirrors the glass is held by a wire clip about 2" long at the top, unhook it and the glass can be taken out. The motor drive can be re set,the white pegs in the rubber boots have come right out. they can be centered and pushed back.
Malcolm
No sorry your glass just levers out from the front, put a flat blade in the outside edge and gently lever out.
Malcolm
