1 - 8 of 8 Posts
1991 190E 2.6
Hello everyone. i am new here. i am wonderinf if any one can help. I have a 1991 190E 2.6. My problem is that out side temp reads all the time -38. Does any one know how to fix this. or what i have to do to fix this. Any help would be great. Thank you in advance. Also does any one kow how to pull the insturmantel cluster out from the dsah.
1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
I dont think its a faulty display. I have a friends that shows -38 on start up of the car and then it goes blank. This happened after the shop removed and sent it to a odo shop to repair it. I think they plugged it wrong thus the negative reading. Does your stay on -38 or does it go blank after a few secs?
sounds like its reversed....the problem is yanking the cluster out to switch the switch around. That is not fun....
1992 Mercedes 190E 2.6
The sensor itself may be open, or the circuit going to or from the sensor may be open.
To test if the sensor itself is open:
Disconnect the sensor, and jump the two terminals where the sensor goes. It should read very hot on the dash display.
To test if the circuit going to or from sensor is open:
Find a way to jump the wires together, it should read very hot on the dash display.
PS: Automotive student.
1 - 8 of 8 Posts
