450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro 300sel5spd R+C107galore
Pink AMX with a tilt wheel. It definitely has a story tongi with it.
http://youtu.be/YsQvxZbiiac
Yes, even a freaking AMX had a tilt wheel. Why MB couldn't put one in our 107s? I guess they thought is was still a sportscar or something. It makes me want to see if the column I think I have around from the 1972 could be converter. There's not much to the column. I think the problem is that the dash is in the way. So a longer column would be required to make anything tilt. I remember seeing scratches from the steering wheel on some of my cars' clusters. So it's almost as if a tilt hub would do it. Ahh... Back to the eccentric adapter. Hmmm... Maybe stack a bunch if those up on a shorter hub.
