2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
Run the same pressures that you normally would, 35 psi all around. The narrower tires with the higher pressures will punch a narrow hole in the snow, and bite the asphalt better.
The contact patch on the snow will be long and narrow as opposed to wide and short. Because you are disturbing less snow, you get better traction.
(At least that was the way it was explained to me.)
