Banned
1991 560sl / 1987 300TDT / 1995 E300D / 1994 S350D / 1993 300SD /Cummins Diesel PU /2 airplanes
I cleaned out the fuel tank on my 1987 300tdt ,changed the online and spin on filter put in new diesel and cranked it over....10 sec...20 sec....30sec and it started to have ignition but I got.nervous and let the starter cool down for 20 min and then gave it another go....20sec.... ..30sec...and it was just about to start when the starter stopped....
Is there a separate fuse for the starter? Could I.have been lucky and blown a fuse? Anyone know where the fuse is or how I can test for burned up starter without removing. I working on it now. Thx
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
I'm not aware of a fuse, but you may have burned up the starter solenoid...or your ignition switch is going bad...or you have a bad engine ground...or a dead battery
Starter solenoid is one option, but hanging brushes are more common. With proper access you can use needle pliers, or other wrench to jump the solenoid connectors to test the motor.
In the past I could buy new brushes and solenoids as separate parts - now nobody sells $4 brushes, but want $400 for starter.
Banned
Thanks guys...jumped it already....nothing.
Banned
Had a spare starter laying around, installed it and in 10 sec of cranking the engine came to life!!! I'll take apart the old one to see what the damage is.
