1977 300D, 1980 450SL, Genuine Buddy 125cc Scooter
It only starts in neutral.
I assume its the some sort of safety switch since it will start in neutral. At first it was sporadic but now its the way it is.
Thanks in advance!
Sent from my SPH-D700 using AutoGuide.Com Free App
2014 Mercedes-Benz GLK250 Bluetec, 1981 Mercedes-Benz 300D W123
Since they are the least expensive, I would start out with replacing the shift linkage bushings. I had this same issue and new bushings solved it. Then move onto the the more expensive neutral safety possition switch. Just replacing the bushings solved the same issue for me.
1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
X2 on the shifter bushings / linkage adjustment.
