[For those not wishing to wade through this novel, the issue was a bad wiring connector at the LPFP (fuel tank), marginal ground wire connection.]
Newly commissioned following restoration project (no prior experience with this engine*) and have perhaps 300 miles with things running flawlessly (I had been pushing it pretty hard to make sure things were working OK and not even a hint of a hiccup) and then the other day... running around 70mph (don't think I was altering speed or engine rpm to any significant degree at the very moment) when I had zero response from the accelerator. Check engine light and I pulled off the road. Restarted and was able to blast up to speed promptly just before needing to exit. I pulled over at a better spot and scanned using my Foxwell NT510 and came up with three codes: 2017-001, 2021-001 and 2021-001. I had zero errors prior to this. ALL related to low rail pressure: "Rail pressure monitoring via pressure control valve The rail pressure is too low" I cleared codes and finished driving home (about 10 miles) and had no issues.
* The car came with an [extra] fuel rail and engine wiring harness. The engine itself had been replaced (some quick oil change place forgot to put oil in the original engine and the car ended up with another engine). Not sure if the parts were extra from the engine swap or they were part of someone trying to resolve a problem such as I'm experiencing.
I performed HPP testing via my Foxwell NT510 and it runs up to about 1,400 rpm with about 1,400 bar and bucks and then the engine dies. This behavior is repeatable. Triggered 2021 and 2047 codes.
Quantity control valve? HPP?
