1988 560 sel
just about 2 days ago i rolled the od to 220000 miles
Now almost right after i have a rough idle and the car is hard to start both cold and warm and i usually have to use the gas pedal to start it ..... when its cold i can crank for about 12 secs then it starts but its a really weak idle like below the 5
And another question i seem to have a leak from my ps and trans .. any common areas that those would originate from i really want to get those leaks taken care of beacuse it leaks on to the exhust and smokes it up after warm up
Ps: when i take off from a light its lumpy but in motion like around 40 mph its silky smooth
1982 280 se aut. ecc. - sold
So, do a forumsearch on "rough idle".
That will provide something to read for a while!
gr J
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Have you done a forum search?
If not sure how, go back to your 'hydraulic oil' thread, it's posted there.
Cheers
90 300 SE
Check your Cold Start Valve. My 300 was hard to start cold. $20.00 to the junk yard fixed my starting problems. Im not to keen on the 560 suspension, but if you use the search tool you will find an answer.. :thumbsup
