1 - 9 of 9 Posts
1980 300D
I removed the under dash trim below the steering wheel and discovered the insulation was soaked with engine oil. Would this be from the oil pressure gauge? Is there any other oil source under or behind the dash? The ignition switch is dry and I cannot find a leak. This would be a MAJOR headache to clean if it gets worse. Anyone have oil dripping on their shoes while driving?
1981 280e
The only reason for the oil would be the pressure gauge .
It has a line running from the engine , you will need to
remove the instrument cluster to get at the connection at
the rear of the oil gauge.[:)]
W123 280E
Inside the pressure gauge is a brass spiral that has oil inside. That could leak. You can fix it by resoldering the closed end of the spiral.
'81 300TD Turbo
This is also caused by oil getting back to the ignition switch assy. from the shutoff valve on the injection pump (if your car is diesel).
1990 300SE, 1983 300D
Happened to me too. I left it alone. [:D]
1982 300 CDT
Hey- If you ever want to get rid of that CDT, let me know. I have one identical in appearance... only 3 years older and 125K more miles. I'd love to have twins.
Dave
2008 PT, 1998 neon--1965 VW 1200
heya 82!
where do you get your parts locally? i have no idear where to get anything for this car! well, besides autozone, and thats no good![:p]
1980 300D
I read another post about the vacuum shutoff valve pumping motor oil through the vacuum lines and dumping under the dash. Anyone else experience this?
'81 300TD Turbo
DOUGLAS MARTIN - 3/29/2005 4:44 PM
Yea, quite a few people. I'm dealing with it now. Gonna change the valve tomorrow if the weather holds out and I can get home early enough.
1 - 9 of 9 Posts
