1 - 9 of 9 Posts
1984 Mercedes-Benz 300SD Turbo; 1985 300CD Turbo
Good day everyone. Well, since I purchased my '84 300SDT the oil pressure gauge has been a bit erratic. It never settles between the 1 and the 2 like my 300CDT; however, it also never settles. It erratically fluctuates between just below 2 and all the way up to 3 when at operating temperature idle. I have a feeling that this is electrical issue; however, I have no idea how to track this down. Or, it could be something else? I really don't know. The care runs fantastic and has ZERO oil leakage. Any help would be greatly appreciated.
Warmly,
[email protected]
1982 Mercedes 300D Turbo Diesel
Sounds similar to my latest post except it's my tachometer that's acting up. Let me know if you figure anything out.
85 300D
well there's no way it can't be an electrical issue.
your oil line could be clogged, there is a line running from the oil filter housing to the back of the gauge cluster. also the o-rings on the oil filter cover could need replacing
the tach has nothing to do with oil pressure in any way
do a search on "oil pressure"
Why couldn't it be electrical? It looks there is a break in the circuit that is causing it fluctuation. However, I will certainly check to see if the oil line is clogged. I just did an oil change and the o-rings were 100%.
Does anyone know how to clean that line?
[email protected]
Replace the oil pressure switch. On your SD that part can be anywhere between $25-$85 new, depending on what brand you go with. You might be able to find a used one on eBay.
The switch sits at your oil filter housing, and takes about 10-15 minutes to swap out. If it were me, while I was at it I'd probably go ahead and do an oil and filter change, and replace the oil filter housing gaskets. Good luck. PM if you've got questions or check with the 126 guys.
1 - 9 of 9 Posts
