1 - 20 of 30 Posts
SL500, CL55, E350, E320
I discovered some oil leaking from the top right of the windshield where the [passenger] sun visor attached. Does anyone know what this is? Is this related to the locking of the top?
And how to fix it if possible?
Thanks much in advance.
'05 SL65 AMG
Yes, I would say the top latch is leaking. I'm guessing this is on the 95' model.
Thanks Jim,
Every time I open or close the soft top, it leaks more since the pump works, I think. Do you happen to know how much it would cost to fix at the dealer?
By the way, this is the 99' car.
'05 SL65 AMG
Sorry can't help you there. I personally would do the repair it myself.
'05 SL65 AMG
There are some latches posted on ebay.
http://stores.ebay.com/fivestar007_Convertible-tops-and-sunroof_W0QQcolZ4QQdirZ1QQsclZallQQsotimedisplayZ2QQtZkm
Thanks Bob and Jim for you info. There are so many different ones out there and I have no idea which one to select. The part numbers are also different. Which one should be the right one?
Thanks again.
Outstanding Contributor
'03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
If you are going to buy from the eBay seller, you want to get one of the items like item 2438304724 . But that would be a poor choice. All you want is the hydraulic cylinder which attaches to the lock mechanism and not the complete assembly. And why accept a used cylinder when a new one is just $125?
Bob,
So the only part I'd need is the cylinder (part #129-800-16-72) ... or however you'd call it, is this true?
I don't want to buy the wrong one and end up losing another $125.00
Thanks much.
RE: the only part I'd need is the cylinder (part #129-800-16-72)?
Yes.
Discussion Starter #11
Thanks Bob, I will try to order it tomorrow through the suggested site. I will let you know the outcome.
Discussion Starter #12
Bob,
I received the part (hydraulic cylinder) this afternoon. It looks so small just slightly bigger than my toe ?!?! From the amount of oil that leak from my sun visor, it is impossible to hold that much of oil. Am I getting the right part?
Also, do I need to add oil to that "toe" before I replace the old one or does it already come pre-oil (inside)?
As always, thanks for your help and sorry to ask so many questions. My first time fixing something so I just want to be sure.
Best,
SL
Discussion Starter #13
BTW, the part I received look like the silver part on the left end of this picture, is it right?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=2435585561&category=33652
Congratulations. You got the right part. It does not have fluid already in it, but no need to add any. And no need to bleed the air out of the system either.
Discussion Starter #15
I will try to fix it tommorrow's morning if it's not raining. Hope I don't have to tow my car to the shop [:D].
From the way you and other described, it seem like the simple job to do. Why (and how) did the dealer charge the other guy $1,600.00 for it?
Have a great weekend Bob. and thanks
Discussion Starter #16
I replaced the hydraulic cylinder. You were right, it wasn't that tough consider I know next to nothing about car. I didn't have the star and hex keys though so it took me a while to replace it, well, 2 hours.
Now that when the front is finished, there seems to be a problem with the rear! when the soft top is in up (closed) position, things are fine. But when the soft top is in down (open) position, the "flap" cover (the one that looks like the U-shape when it is up), where it covers the compartment that holds the soft top does not want to go down. It stays straight up.
I looked into it to see if there were any of the hydraulic cylinders leaking but found none. Does any of you know what causes this not to work when the soft top is down?
If it doesn't close the whole time, then there must be a problem. Now that it only works half time (I know it is still a problem but) it confuses me.
Please see the pictures below. I have to manually push the cover for it to close (still doesn't lock though so the light on the switch still on).
Thanks in advance for any help.
Best,
SL
RE: Compartment cover won't close
The problem is surely the signal to the controller that the top mechanism is lowered into the storage compartment. The plunger-like limit switch in the picture below on your car may not be closing.
When the opening operation stops, get out of the car and use a screwdriver to push down on the switch. If the switch had been open it should now be closed. Continue with the opening operation. If the compartment cover now closes as it should, you need to adjust the switch. If it still won't close, you will need to test the switch electrically through diagnostics.
If you need to adjust the switch, use a small flat-blade screwdriver to cause the switch to close with less plunger travel. I don't recall whether you loosen or tighten the screw to do this, but if you look at it closely I think you will figure it out.
Discussion Starter #18
Thanks Bob. I have no idea what switch you were talking about but all of the sudden, the cover works again. I tried few times and it was fine so I guess I just cross my fingers for now. [:)]
It seems like you know everything about the R129? Are you a mechanic?
Just out of curiousity, why do they call it R129 while W208 (why not R208) ... what is the R and what is W? Seems like R's are for SL and SLK and W's are for the rest. Perhaps, R stands for Roadster? ... no idea [:p]
I'm not a mechanic. But I've always done my own repairs. And I've learned alot about the 129 convertible top because the first 300SL I owned had many problems.
That switch for the convertible top in compartment is in the area shown in the photo.
1 - 20 of 30 Posts
