1992 180e
does anyone know where to start looking for engine oil in the cooling system its a 1992 1.8...its not bad yet say 50mls in 100k and is in the top of the reservoir
98 SLK230K AMG, 98 E55T, 89 2.5-16
my experience cylinder head gasket or warped head, and sometimes very seldom but happens as well - hairline crack in the head.
i am not familiar with the other engines. mine is a 16v and it has an oil cooler right beside the radiator. are you sure it is oil? it might be ATF, leaking from the ATF cooler in the radiator. that is if you are driving an auto transmission.
regards,
ray
1992 180e
its engine oil. as clean as.not mixed with the coolant at all.. i have to think that it is an oil pressure leak but i cant see a cooler anywhere external
with or without an oil cooler, you have an oil leak somewhere in the engine that is going into your coolant line and they are not supposed to meet anywhere.
